Hi, My Ideal Logic² Max Heat 15kW boiler has been in and working since December last year. You may find posts of mine around that time about setting it up in Priority Domestic Hot Water mode in conjunction with Open Therm.
I've lived with the fact that the boiler cycles a lot when the room set temperature is approached because the boiler can't modulate down fast enough or low enough for the requested flow temperature.
Although it is not going to be perfect I would like to try to extend the off time of the cycle and am hoping that there is some hidden menu where is is possible to set the cycle time? Any pointers much appreciated.
