Gary,
I thought I'd let you know how I got on, and maybe give you a few pointers from one novice to another.
Basically I'm pretty happy with the joints. They fit 99% perfectly, but the colorseal masks the other 1% pretty well. It was also pretty time consuming in the end - not really sure where the time went actually.
A few thoughts on reflection:
1. The tools were rubbish. Clamps were a waste of time and we ended up buying two G clamps from B and Q. The others kept sliding.
2. The depth plunge locking handle also snapped meaning we had to lock it using a spanner, and effectively making it a 2 man job. I bought the more powerful orange router.
3. Only the 63mm bit is long enough to cut these worktops in the router I had, once the thickness of the jig is taken into account. Fortunately I bought an extra box of bits. You can use the shorter ones for the bolt holes.
4. 10mm is too much to take off at a time comfortably. I smidge over 5mm is all I'd go to in order to protect the cut and the router bit. Better bits may be able to take more off.
5. Ensure the router is fully stopped before removing it. Otherwise the jig will get cut
6. Make sure you either support the front edge, or constantyly remind yourself that you are pulling towards yourself BUT putting the weight on the side of worktop away from yourself. Otherwise when it cuts through the router will drop and make a bad cut. I'd also suggest a friend holds the worktop so it doesn't just snap and fall to the ground.
7 When you come to bolt it together and apply the colorseal, turn the worktop on its side to apply the colorseal. Its so runny most of it will go on the floor if you try to apply it when horizontal. Dont worry about mess - the solvent is very good despite my concerns. The colorseal is now on sale at both
Wickes and B and Q.
8. Before you cut the female joints check whether your kitchen walls are square by putting the other piece of worktop in place - it will be difficult to tell once you have cut the female joint. Mine was square fortunately - someone else will be able to advise what to do if it isn't - I believe you adjust the male.
9. Leave the male worktops long if you can as you can have another go if you mess it up.
10. The other tip was to keep your practice pieces handy as a sanity check before cutting. Put it next to the jig face up/down and ensure the cut matches.
I think thats about it. Hope some of this helps you. Apologies for stating the obvious, and apologies to all the 'experts' who already know this stuff as obvious, but some of it I hadn't realised myself.
Finally, thanks to all who have contributed to this post, it made the whole process much easier.
