- Joined
- 30 Mar 2021
- Messages
- 20
- Reaction score
- 0
- Country
And then you're left with a savage clean up and repair billThe tenants will probably trash the place in a year or 2 so I wouldn't worry about it too much it's not dangerous
Also, you do not remove skirting and Wickes will give you one of their little instruction leaflets if you care to ask.
In an ideal world the skirting would be removed, but on older properties, you will risk pulling off quite a bit of plaster from the walls, as well as damaging the skirting nailed to wooden grounds. By all means do that but it will add significantly to labour costs. A suitably mitred quadrant primed painted to match and pinned will be fine for most domestic use.
You can buy softwood and hardwood quadrant as well as the MDF stuff - but it generally isn't finished, so it will need to be stained and polished or primed and painted. It also needs to be pinned to the skirtings, NOT the flooring (obvious, when you think about it, but folk do get it wrong)To an extent I agree, but not using the quadrant sold for the job, it seems to be compacted cardboard and the slightest bit of moisture it explodes. Rather use the much cheaper plastic quadrant, sold for UPVC DG. Door frames are impossible to make a tidy job of with the quadrant.
I've done it three ways - fitting new skirting is quock and is the easiest wzy to get a good finish - removing old skirting and refurbishing it then refitting it can make for a better looking job, but there is often a lot of make good work required and it is the slowest way (and with some mouldings may in fact be the most aesthically pleasing approach) - whilst quadrant is the "least work" option. Yet pays yer money...Better, is to either remove the skirtings and undercut the door frame, to allow it to slot under, or under cut the skirting too if it cannot be removed
