- Joined
- 27 Jan 2008
- Messages
- 27,503
- Reaction score
- 3,325
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I do note:- "by convention, not a PEN conductor." so it does seem, even back in 2008, there was some uneasiness at not classing the PEN as live. Back in 2008 we had for caravans and motor caravans "NOTE: In the UK, the ESQCR prohibit the use of a TN-C-S system for the supply to a caravan." and clearly if a motor caravan came under that rules so would have any other similar motor vehicle.BS7671:2008 said:Line conductor. A conductor of an a.c. system for the transmission of electrical energy other than a neutral conductor, a protective conductor or a PEN conductor. The term also means the equivalent conductor of a d.c. system, unless otherwise specified in the Regulations.
Live conductor (see live part).
Live part. A conductor or conductive part intended to be energised in normal use, including a neutral conductor but, by convention, not a PEN conductor.
So we have hot tubs, patio heaters, and EV's which are often not class II, and we are now starting to switch the earth, which seems to go against the grain, I looked for socket outlets used outside, but that must have been the 16th edition, the 17th needed all under 20 amp to be RCD protected, but to my mind a socket outlet which is likely to be used outside the protective equipotential bonding zone should not use TN-C-S earthing system. The earth is connected to my external socket, but I only use class II equipment in it.
However, lighting seems to be the odd one out, no tool required to take cover off a ceiling rose, and the protected against an object 12.5 mm (IP2X) is also not complied with. We have had plug in ceiling roses for years, but except in a bathroom, they were not RCD protected, so why lights with plugs and sockets is different to power plugs and sockets I don't know.
I would think the light fitting shown is BS EN 60238 but can't see any marking on the picture.
