Does that mean it was less ambiguous than a very ambiguous response would have been?
but if i were building, lets say the Akashi-Kaikyo bridge in Japan, then i would certainly allow "a greater measurement at the top of my columns than at the bottom.
i would imagine it will apply only to suspension bridges, as these cover huge uninterrupted spans and use very tall columns. the differences are only in the realms of 20-50 mm between top and bottom measurements and are only relevant to engineer checks and gps.
a large bridge deck and superstructure can flex and wane as much as 2m. so i guess 50mm ain't gonna matter an awful lot.
as i said the checks are there to make sure the columns are perpendicular.
Pretty useful, but as with many tools you get what you pay for. Cheap lasers don't last and aren't all that accurate - a builder's 1m level, however is generally pretty accurate and lasts for many years (my Stabila costs £70 these days and is approaching 25 years old).
hogster said:
just want something pretty basic for using when putting up shelves etc, just wondering how they fix to the wall for "easy hands free operation"....notice the B&D models have pins....doesn't that mark the walls/surface, any advice would be much appreciated.
The answer is that with many machines you nail or screw a mounting plate onto the wall then hang the laser on that (at least that's how the Bosch I have works as do some of the Pacific Laser and Stabila models I've used, too) - so that does tend to mark the walls, although in a new kitchen or a new build that's hardly a problem . In general, though, I use my laser level on top of a tripod (in my case a Velbon AE photographic tripod I've had since my school days!). This allows me to draw a single horizontal datum line from which I measure up and down to get my other horizontals and drilling points, turned through 90 degrees I can also mark verticals in different places by swivelling the laser on the tripod's pan head. I doo however feel that a cross-hair laser would possibly be more useful for me in the sort of work I'm now doing.
