Clip pipes where possible, if a ball a fix is fitted turn the screw to one oclock to lower pressure to the ball valve, may fix problem.
That wouldn't work , I can't understand why nobody has suggested a new washer in the float valve. Am I missing something.
Ah but doitall you may be reading too much into the original post, for instance the op said it happens for a while then stops for a while, maybe his neighbour works funny shifts.
Have a peek through here, you may get a better feel for it.
http://www.askthequestion.co.uk/phpBB2/viewtopic.php?t=5323[/QUOTE]
I see, if only he knew, you scruff
do you know this scruff geeser
but what is the answer
