Need to raise my currently wooden floorboards by 9.5mm to be level with the kitchen and utility which are currently tiled. A few questions though.
1.) My local timber merchants sells hardwood WBP and Softwood ply, about £4 difference per sheet, which should I go for ?
2.) Understand I should leave about a 10mm gap around the edge for possible expansion but each sheet should be butted up against each other.
3.) When I reach the kitchen with the tiles, should i butt the plywood right up against the tiles or leave a gap there, assume it can't be too big a gap otherwise when i eventually fit the LVT transition bar it will be too low.
4.) Laying plywood, will be over the hallway and into the living room. Should I leave a gap in the plywood when it goes into the living room ?
