Laying slate slabs as a hearth
29 Mar 2011
Gwynedd
I'll soon be fitting a new Morso stove on a plinth in the fireplace.
I've already laid down some old 1" thick slate slabs on the plinth, bedded in a sand and cement mix and I now need to grout them.
What kind of grout would be best, or would a sand and cement mix be OK?
The stove is 5kW.
Thanks,
steve
You should be using a proprietary cement powder tile adhesive rather than mortar mix which may fail with heat; don’t grout with it either. I don’t use grout in high heat applications at all as it tends to fail with continual expansion & contraction. I space tiles at 1/2mm & use silicone.
I assume your aware installing a stove is controlled building work? It must comply with several Building Regulations (including the hearth) & you will need a compliance certificate. Don’t use gypsum plaster/plasterboard around the stove either; it will fail & fall off in a very short space of time.
