Flashband will look similar to the black silicone and I could still bond a mop stick to the top of the glass. I filled it with silicone as it was tiny and the glass butted close together forming an sharp apex. The silicone filled and flattened it. I now have a flat top that will flashband and give another layer of water resistance and the black neat finish on the inside. I now can either bond a thin mop stick to it (can you but a thin long piece?) and then bond a strip of lead over the entire area, or by a piece of the fibre ridge mentioned previously and bond that.
The tricky bit will be the 2 wide, angled ends. A straight piece would do the middle section but how do you finish the ends without using a massive, ugly piece. £ sections? one on each end and then the straight over it? A sort of I shape?
