Leaf Blower
7 Jan 2011
North
Ireland
Hi
I have a Leaf blower, its runs ok but when I got to give I the welly it cuts out???
New spark plug, filters have been installed but I think its the carb not set correctly.
Does anyone know how to go about setting a carb?? I have been reading to turn L & H screws anti clockwise to fuel close the idle screw and open 1/4 turns (after warm engine) then work the idle L screw clockwise to get good idle sound then work on H screw for accelerating setting would this be correct?
Any advice would be very much appreciated?
It's probably best to set each screw around 1 turn out, and then adjust from there - which machine is it? There's a good chance the carburettor may need new diaphragms fitted plus a clean.
John :)
Ok, that’s the back pack machine.
The carburettor has two diaphragms and two gaskets.....one is the pump side that pulls fuel from the tank and the other is on the metering side which controls fuel flow through the jets.
I’d recommend that a new set of diaphragms / gaskets is fitted, not too difficult but you will need a can of aerosol carb cleaner and preferably a supply of compressed air.
Inside the carb is a very fine filter which will need a look at too.
If you fancy a bash to repair, remove the orange covers, the air filter and fuel lines, together with the throttle cable. The carb will then pull off its studs.
Id recommend the genuine Stihl parts at around £15,but pattern bits are available.
John :)
Thanks Burnerman
I will set to set the carb first by screwing the idle screw in then 1 turn out and having the L & H screws out anti clockwise before I start tampering with the removing of the carb
That’s fine.....when the machine dies, see if a quick application of choke makes it cut back in again.
When you are experimenting, have the tickover set on the high side.
John :)
