OK, that'll probably need a drop of silicone on both sides of the rubber sealing washer inside the cistern roger and it probably needs a new fibre washer where the connector fits onto the inlet valve pipe.
Oh BTW, the dual flush should work by how far the rod pushes down, if you hold the button down when flushing do you get a normal flush?
