Leak
16 Oct 2006
I have a Vokera Linea 7 boiler, and it's just started leaking slightly. It looks like it's coming out of the safety valve. When I turn it on, it says there's not enough pressure to start the boiler.
Is this something I might be able to fix myself by tightening the safety valve, or should I be calling out someone to have a look?
Great timing :rolleyes:
thanks
The valve on that boiler is push fit so you cant tighten it.
Its an easy job to replace if you are confident.
