Hello all
Currently having a spot of bother with a soil pipe, following getting a bathroom fitted.
Sorry this is a bit of an essay, trying to get the relevant info in.
I had a bathroom & ensuite fitted in Oct 09, and there have been a few problems to resolve along the way - & still not quite there!
The pic shows where the internal soil pipe joins the waste on the ground floor of the house.
The black soil pipe is plastic; this fits into the ceramic pipe going underground and is sealed in with cement.
Both bathrooms are on the first floor, directly above.
In order to accomodate the soil pipes from both of these, the vertical soil pipe was moved to the right by a couple of inches, part way up the height.
This movement seems to have caused some leaking, which seems to be coming from the right hand side of the cement joint. It doesn't seem obvious exactly where, as a lot of rubble was left in the cavity, which all got wet.
There is no sign of any water running down the outside of the soil pipe from the connections above. All seems well above.
I would prefer the builder to sort it out, as I know it wasn't leaking before.
(I posted on here about 12 months ago on how to deal with the boss on the pipe, and the original pic is still in my album).
My dilema is whether to try to sort it myself, or keep on at the builder to sort it out.
He is due to back to fix another couple of things (still) - faulty flushing in the ensuite toilet and condensation leaking from the ducting in the loft from the extractor fans - a previous post in Building)
Unfortunately builder is starting to lose interest.
Would sorting this cement joint out be a difficult job?
It may give me more chance to get him back if I can reduce the job count!
Thanks in advance.
Thanks in advance.
