My house is a semi with the down pipe in the middle of the building, between me and next door, its leaking at the joint, the reason for this is the hedge roots are growing up the down pipe as the underground pipe has collapsed, i discovered this when i dug down to find out what the problem was, and it seems to go through next doors garden.
As the down pipe is cast iron is it possible to drill a hole in it without breaking it, so that the water does not run down the wall at the joint.
