Drilled a hole directly where the leak was.
I have drilled a hole where the leak was. Looked up, and I can see the inside of a chimney and the inside of a chimney pot.
The camera is facing directly upwards to where the leak is coming from. You can see the inside of a chimney and the chimney cap at the top. You can also see the wood holding up the chimney.
The chimney breast would have been in our room. That was removed, so the chimney sits above the plasterboard ceiling in our room.
EDIT: The water is dripping of the flashing you can see which seems to be towards the bottom of the chimney - which is why I always felt the dripping had some "force" behind it - as it was dropping from height.
Where the water is coming from that is dripping onto the flashing around the base of the chimney - that is a question mark.
The torch is somewhat in the way on the left
How do I make the chimney cap completely water tight?
