Newbie here.
I have one of those "bum gun" portable bidet things, which has worked fine for the last 18 months since it was installed. It consists of a tap on the wall, connected via a flexible shower hose to a handheld shower unit with a spray trigger. The other day it started leaking (fine in the morning, unusable by afternoon, with no use in between), with water running down the flexible hose.
At first I assumed the hose itself was faulty, but after unscrewing the trigger/shower section, the hose had no leaks at all. When the trigger is pressed, the leaks from the body of the unit stop (as the pressure is released, I guess?)
When I removed the shower section from the hose, a little perished orangey-brown mess fell out, which I can only assume is some kind of washer (or, Google tells me, possibly a "friction ring", whatever one of those is?).
The rubber washer in the hose seems fine, and the O-ring at the trigger end seems OK too (both have been replaced and made no difference). So I can only assume this orange brown thing is the culprit. However, I have no idea what I'm actually asking for in a shop, as I don't have the old one to compare. When I asked the guy who'd worked in the plumbing shop for 40 years, he had no idea what a friction ring was, so internet research not much use there! He suggested it might be a fibre washer, so I tried the only one of those I could find in the shops that actually fit (though I couldn't determine the thickness of the original, so that may be a factor?) I also tried some PTFE tape around the thread, but that also had no effect on the leakage.
Can anyone shed any light on what the required component is likely to be? Is it indeed a friction ring? Where in the assembly would such a thing fit (in the hose or on the shower section, or directly in between)? Or even a way of identifying the actual problem? I guess it is possible that during the disassembly another crucial part may have fallen out and out of sight somewhere.
Thanks for reading. I spent hours puzzling over this the last few days, and thus far only succeeded in getting repeatedly soaked, so any help is most welcome !
