Getting fibre washer over the thread made me choke on my pint
Not sure what you mean?
The residue from you spraying the nuggets off your chocolate starfish can be drawn back into the mains, and bacteria can travel against the flow of water, leading to contamination. Normal shower heads have to be restricted so that they can't reach a toilet bowlTo everyone posting about contamination, how would that work? It's essentially a shower that sprays into the toilet bowl, so where does the contamination risk come from? This is a genuine question by the way, not just being facetious!
A fibre washer or in this case a rubber washer fits between 2 flat surfaces to make a seal. From your earlier post re PTFE tape I`m thinking you tried to seal the connection everywhere except the correct place.Not sure what you mean?
They shouldn`t even reach the water in a bath. (shower over bath situation).The residue from you spraying the nuggets off your chocolate starfish can be drawn back into the mains, and bacteria can travel against the flow of water, leading to contamination. Normal shower heads have to be restricted so that they can't reach a toilet bowl
Newbie here.
I have one of those "bum gun" portable bidet things, which has worked fine for the last 18 months since it was installed. It consists of a tap on the wall, connected via a flexible shower hose to a handheld shower unit with a spray trigger. The other day it started leaking (fine in the morning, unusable by afternoon, with no use in between), with water running down the flexible hose.
At first I assumed the hose itself was faulty, but after unscrewing the trigger/shower section, the hose had no leaks at all. When the trigger is pressed, the leaks from the body of the unit stop (as the pressure is released, I guess?)
When I removed the shower section from the hose, a little perished orangey-brown mess fell out, which I can only assume is some kind of washer (or, Google tells me, possibly a "friction ring", whatever one of those is?).
LoI does that toilet come with a wireless controller aswellI hope no one drinks the tap water in your house or Street for that matter! You might well be drinking your own faeces fresh from your 'Arris
Are you Muslim? I know they have to wash their backsides before praying but most usually use a jug with a spout.
If you insist on using this type of bidet then at least use the type that is integrated with the toilet rather than the water supply. A bit like this one:
Can it be linked to nest or hive productsdoes that toilet come with a wireless controller aswell
Nothing wrong with it at all. The model in the picture is not naked.There's a lot wrong with that photo
not sure your logic there... where is the "residue" going to go from that distance, who's that person holding the remote and why are they in the room, and surely you should clean before pulling your underclothes on not afterNothing wrong with it at all. The model in the picture is not naked.
I think you're misreading the pic. The model is doing a wee in the toilet (the wee is flowing downwards) and then when she finishes the guy is gonna press the button and clean her. Any way that's how it looked to me.not sure your logic there... where is the "residue" going to go from that distance, who's that person holding the remote and why are they in the room, and surely you should clean before pulling your underclothes on not after
You don't know women very well do you
A lot of women do not like to sit on toilet seats and perch instead. Just like the model is doing in this pic
