Leaking roof / box gutter! - what do I do?
Hardme, we have a large contract in Cambidge that usually sees a couple of calls a month, pm me your number if your up for some work there.
If it's the step - them why hasn't it overflowed in the past five years?
Not only that, it would pi$$ in if it overflowed.
If you read the thread properly, you'll get an understanding why water is overcoming it, its a height/flow/quantity thing.
Now i understand reading some of your posts that you're a bit clueless, but can't work out why you're such an obnoxious ****?
Grow up FFS.
And I've read the posts, and I still don't see why it hasn't leaked years ago, and the ceiling still needs repair. Gediit yet? Or are you just one of natures *******?
Ahhhh, keyboard warrior, stick it on your CV, under knownothing.
Now you are showing your true colours. :rolleyes:
My two cents would be:
1. I'd take joe's advice and, for a start, take down the stained board.
2. On a dry day, get out there and clean/wipe the gutter.
3. Start lightly water testing from the outlet up the fall. Short sections of gutter. If the leak is in the gutter this testing will pin-point it.
4. Keep going inside to observe - take your time testing and observing.
5. When a suspect point/area is located, then i'd take xenon's suggestion and "clean, prime and coat ... " etc. AAMOI, zinc can be glued with waterproof epoxy.
6. hardmetal's analysis of the defect/history ( lead to zinc with incorrect substrate for one piece zinc) is spot on, but to refurbish would be expensive, and no matter how good i'm sure his repair would be, it should still be tested and observed from below. Hence, the p/b removal.
note: remove the brick and any debris from the parapet and secure the flopping tv aerial.
The d/h window frame and trim req's attention.
