We have a Victorian semi, with an exposed SW-facing 9" rear wall, currently painted brick, although this is peeling in parts. We had 4m double-doors / windows put in (nearly full width), replacing small doors and window. When the opening was made and the steel put in, we noticed that rainwater was coming down the inside of the wall, and also seemed to be coming down the middle of the 'solid' wall, too.
(An aside: builder didn't use a cavity tray because it is supposedly solid, but since there's a gap of a few mm between the courses - aside from those bricks that tie them together - it doesn't seem solid to me, in terms of water anyway).
The job has been finished, and all small cracks that opened up externally above the steel have been filled; yet the leaks continue, with water evidently running down either the middle of the wall or the inside, hitting the steel and tracking inside (rather than out through weep holes drilled as an attempt to solve it). Windows on 1st floor and attic conversion have been replaced recently (PVC instead of rotting wood), and sealed properly I believe.
There were damp patches before the work was done (internal plaster on 1st floor, brickwork on ground floor to about 3ft), which suggests water was coming in and I guess could have been running to the floor unnoticed.
Final point: many of the houses in the road have had their rear walls pebble-dashed or rendered. The mortar is very soft.
My question: would it be considered normal for a wall of this type/age to let in so much water? Was that the design? Is it even feasible that repainting might solve the problem, or should I be considering render?
Apols for long post, any advice welcome, I'm struggling to get anywhere.
