- Joined
- 1 Dec 2024
- Messages
- 2
- Reaction score
- 1
- Country
I would like to build a lean-to (open on three sides and the other side on the house brick wall), however there is a gas boiler flue outlet on the wall which will be about 200mm below the roof of the lean-to? There is a door which is 300mm away from the outlet of the flue. The flue would be on edge of the lean-to (see image attached). Would I need to extend the flue away from the lean-to, or is there enough open space for the setup as it is currently? I tried reviewing as many regulation references as I could, but I'm still not sure. I could make the lean-to a bit shorter on the left hand side, but ideally would want it to cover the whole way along.
