Thanks for your reply. I could do that but have a fence at the end so won't serve much purpose. So I am guessing if its not attached to the house I don't need building regs?
Its an extension regardless of its construction as far as B regs is concerned
I would only class it as a covered way if it was permanently open ie no doors, if doors are fitted its an extension, unless its fitted with a clear or translucent roof. Your LA may take a different view but thats how I would deal with it
Thats why I said your LA may have a different opinion. If it was not open ie fitted with doors then I would not treat it as a covered way and insist on an application as did the last two authorities I worked for.
I’d look at the possible need for access for construction and maintenance so what could you fit in, or if that’s not a concern well 50mm is used for air flow in many instances ( does seem a little small for this) and I’ve actually found 2 LA who define covered as a attached structure with a door at either end and several more that just don’t define them
Access is not so much an issue as am planning to prefabricate the walls and bolt them together, also thinking to use pvc cladding so maintanence should be minimal.
As I have already repeated, this is my personal interpretation as well as my last two authorities, other BCO's and LA's may take a different view, so there's not much point discussing it further until it has been confirmed either way by the LA in question.
Actually this is the sort of work I would probably drive past with a set of blinkers on if I saw it in progress to be honest, but they have a tendancy to come back to bite you when neighbours complain.
Thanks for your reply, so when you say allow for some movement do you mean to keep it detatched from thd house and build a seperate wall? I thought of this but was concerned with the small gap between the house and shed getting damp
