- Joined
- 27 Jan 2008
- Messages
- 24,922
- Reaction score
- 2,881
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My mothers fridge/freezer does not have enough freezer capacity to allow a weekly shop so we bought a second freezer which sits on top of the main one and the carers move food down as the food in bottom one is used.
This small A+ 32 litre freezer by LEC will hold around 30 ready meals each time it is emptied it's turned off so gets a regular de-frost. It's about 2 years old.
I had no reason to suspect there was anything wrong with it but as an experiment I decided to plug it into an energy meter to see how much it used. I thought I had made a mistake so re-tested. Test time 335 hours 39 minutes and power used 9.66 kW and run watts 28. This equates to 252 kWh/annum but the unit is rated at 146 kWh/annum. The extra power used is not really a worry but the mark/space ratio run to idle is because I have worked out it's running for 100% of the time.
Since finding this out I have noted it's never idle however never noted any food which is not fully frozen. Neither have I noted ice cream being too hard. The freezer is shown here
Although a motor could fail at any time to have insulation fail after just 2 years seems a bit odd. All my temperature senders only go down to zero so inside temperature is guess work.
Even at £50 a year it does not make economic sense to change it only one we could get is the same make and model and they cost £100 so would save £25 a year if changed which means 4 years to break even but last one only lasted 2 years so no point.
I am just wondering if I have missed something silly.
