My guess was confirmed my mothers freezer just keep going down in temperature so turned it off again.
I've been trying to get hold of a -80 freezer, so this sounds like it would be just the ticket. Mind if I buy it off you?
I've been trying to get hold of a -80 freezer, so this sounds like it would be just the ticket. Mind if I buy it off you?My guess was confirmed my mothers freezer just keep going down in temperature so turned it off again.
Absolute(ly) not.As I recently wrote to eric, the temperature obviously will not 'keep going down and down', indefinitely, even if it's running continuously.
That would certainly sound far more sensible, given the considerable variation in freezers.it would be better to quote per cubic metre then ??
As I recently wrote to eric, the temperature obviously will not 'keep going down and down', indefinitely, even if it's running continuously. The temperature of the freezer cavity can never get below the temperature of the coolant, and it would make no sense for manufacturers to waste money creating a domestic freezer which did/could achieve a coolant temperature appreciably below -20 ° - hence my experiences with leaving the 'rapid freeze' switch on for several days.
Indeed - as you will have seen, BAS has already made that point (well, I assume it's the point he was making!), albeit in a somewhat BAS-like 'cryptic' fashionThat's disappointing to hear, not only because I won't get my -80C freezer but also because it occurred to me that if he left it going for a few days and got it down to -273.15C, he'd be in line for a Nobel gong. That would certainly pay for a new freezer.
Well, it's obviously the kWh/annum which matters to one's pocket, but one clearly has to take the size of the fridge or freezer into account when making comparisons - one obviously would not expect a massive one to cost the same to run than a tiny one!But it would seem the A+, A++, and A+++ rating are not really important it's better to just look at the kWh/annum.
I think that sums it up well. Maybe I'm cynical, but I suspect that these ratings were not designed for anything more useful than playing lip service to 'the cause'.To my mind the rating is so complicated as to be near useless.
Not just Samsung - plenty of makers do larder fridges and larder freezers which match.Samsung have been crafty here they make a matching fridge and freezer which stand next to each other making it look as if it an American Style fridge freezer but it is too different units.
Even the Real Thing is like that:Today you never get a freezer bigger than the fridge.
Maybe, or maybe it becomes a problem to stop the fridge getting too cold if too high a proportion of the 'box' is at -18° ?Maybe it's simply that people want more space in the fridge than the freezer?
