LED Bathroom mirror
25 Feb 2014
Merseyside
I am thinking of fitting a LED bathroom wall mirror opposite the bath, away from zone 1. It will be a basic LED mirror, no internal heater or shaving socket and no infra red switching.
I want the mirror to switch on when the bathroom light is switched on. Can I simply chase the wall and feed 0.75mm 3 core flex down from the ceiling rose to the mirror through plastic oval conduit straight into the back of the mirror.
Would this comply to the latest regs, I want to do the job myself before having it tested.
Many thanks.
J.
Does the lighting circuit have 30mA RCD protection and what plans have you made with regards to notifying and commissioning the work?
Do manufacturers instruction allow the mirror to be installed in zone 1 or 2?
I have just spotted a reply on here to a similar question.
I will fit a spare 30mA RCD in the loft from the light switch and then feed the mirror and ceiling rose from there. This will come in handy if I install LED downlights too.
My reason for the question was to make sure that it was OK to use 0.75mm flex cable for this job. It will be in plastic oval conduit then plastered over.
I haven't decided which mirror to buy yet, any ideas on specs ?
I have a friend who has Part P but he is on holiday at the moment and I intend to use him regarding notifying etc.
Thanks again.
I would stick with 1.00mm T&E no need for conduit! Safe zones of cable is important!
The rcd will need to be accessible and protect everything you alter!
It will require to notified prior to starting and inspecting and testing to prove it is safe! This is a legal requirement!
