Except 12V is unlikely to light a string of LEDs designed for 24V.
But it would be a safe voltage to apply to the lights initially - if they don't light, then the OP can add more volts.
Or more likely: they come onto a help forum on the internet and someone recommends testing it on a very low voltage which does nothing... so they throw it away thinking it's broken.But it would be a safe voltage to apply to the lights initially - if they don't light, then the OP can add more volts.
The difference is: I'm suggesting using the voltage the system is designed for, IE the correct voltage.So, taking your theory a stage further - they apply too high a voltage, blow that lot, then throw it away. The difference is what?
We don't for sure know what voltage it is designed for, do we?
Oh and 24VView attachment 360769That'll be AC then
Oh and 24V
Let's see if OP comes back with results.24V AC. Which means each LED will be only be lit, for less than half of the time, 50% duty. Tested on DC, they would be lit the entire time 100% duty.
Note the difference, and why I suggested testing with 12v.
