Hi all. I fitted a fitted a LED floodlight in my local pub (in a sheltered area down the side of the pub used for storage). I was replacing an old halogen fitting that had weak bulb springs. Whenever the door slammed the bulb would work loose. The first LED floodlight lasted about 3 months. The replacement lasted about 2 months. From memory it is the following.
Usage is probably 14 hours per week. It is screwed into what I think is a tall concrete lintel. I had to use a SDS drill and did not see any brick dust when drilling about 60mm deep.
Any suggestions as to why they are failing so quickly?
