I have florescent tubes in the lights in my garage and would like to replace them with LED Tubes, so what LEDs will give the brightest glow? and is it just a matter of getting the same size LED tube and fitting it into the old fitting?
Thought it was too good to be true, guy at local shop, "ah its only a matter of removing the old tube and starter and replacing it with a new LED tube"
most do come with internal instructions to adapt the wires.
A basic fleurescent fitting has LIVE one end and NEUTRAL at the other.
If a led tube was fitted direct then for it to work the LED internals would have to be made with wiring end to end, hence a 50% chance if you removed the tube live and touched the end pins you would be electrocuted.
Some safer tubes have instructions to adapt the fitting so LIVE and NEUTRAL are at the same end, problem there is ever a normal tube is fitted, then it could shatter, these rely on you fitting a Warning sticker.
Yeah, but surely thats something induced into the cathode as opposed to the led internal mechanics physically wired to the pins, some of which are a lethal combination of voltage and current with regards to earth
I get what you are saying, I'm just saying I don't see why one is ok but the other isn't.
I'm pretty sure a shock from a flouro could throw someone off a ladder.
LED tubes should be constructed in such a way that there is no connection between pins at opposite ends of the tube.
Some are like that, plenty are not.
