Hi
I am looking to replace the GU10 50w lamps in my garden lights, the set up consists of 6 240v spike lights (each 50W) and a 12 volt mr16 above the front door.
The lamps I am looking at are 4w which state an equivalent of 35w, as the lamps are quite expensive I am planning to replace them in stages.
My question is can I mix and match the regular lamps with the new LEDs? I am looking at replacing 2 at a time. (The 12 volt mr16 over the door will remain in place)
Also the lamp holders are quite small ( the new LED's look the same dimensions as the regular mr16 lamps) will this confined space cause any heat issues with the LED's?
