I'm a little confused now, I thought this was a case of swapping existing lamps for LED's but you make it sound like you have different fittings now.
Do you have spot bars and intend to swap for downlights?
I wouldn't recommend and odd number of spots unless there's a specific reason for it.
A lot of people here will advise against downlights, but it's up to you, I personally, like them in the right situation.
BAS will come along soon enough to lament about 11 lights is too much to light a room when one pendant would do the same job, but in my eyes 11x6w LED's will use no more power than one pendant, so if it's what you want, go for it.
And, I find the 4w philips GU10 LED's are bright enough, so you'd only be talking 44w
