- Joined
- 18 Feb 2007
- Messages
- 1,367
- Reaction score
- 77
- Country
OOPPS!!!!
Spoke too soon. I connected 5 - 6.5W LED down lighters to one Electronic Transformer rated 20-60 W so 32 W load. All worked fine. Left lights on for an hour and then all went out. It appeared that the transformer tripped out possibly on over temperature. A few minutes after apparent cooling, lights were able to be switched on for a few minutes then tripped out again. I heard the sound of a click coming from the transformer suggesting a trip of some sort.
What is odd here is that the Transformer was OK for years with a 60 watt load with two 30W halogen down lighters with no hint of temperature trips in over 14 years of use.
So I thought I would now split the load into two transformers, one feeding two 6.5 W LED/sand one feeding three 6.5W LED's. The two LED loaded transformer seamed OK but the three LED Transformer tripped after about 80 minutes. This is weird as the load on the two LED transformer is only 13W which is below the bottom limit of the rating of 20-60W, and the three LED loaded transformer is only 21.5 W which is well with in the power rating.
These transformers were no problem with a 60W load so what is the problem with an LED load. Just doesn't make sense to me.
My next step is to re-establish three transformers with Two LED's on two of them and one LED on the third and see what happens.
A load of a few Watts to LED's is surely the same as a load to a halogen light and any wave form problems are not apparent as the LED's operate perfectly satisfactorily for well over an hour.
The transformers did feel warm when they tripped and I can only account for the rise in temperature due to losses in the electronics of the transformer, but these losses would be the same irrespective of the Load.
Any switching transients are not apparent when switching on the LED's so there appears to be no problem there.
If my present arrangement fails I will have to bite the bullet and replace the down lights with 240V G10 LED's, but I hate the unexplained failure characteristic of these damn Electronic transformers. The damn things are being used below their specification, so what the hell is going on here.
These 12v LED's are being sold by the High Street outlets as replacements for 12v halogen lights and the 12 V in a domestic installation has to be derived fron a transformer of some sort and most likely an electronic one, so presumably everyone who tries to replace the Halogen lights will have exactly the same problem as I am having.
So electricians out there get ready for a lot of work coming your way from unsuspecting households. Save time and install 240 V G10 units at a fraction of the cost of solving the problem.
Happy days
Happy days
