Outdoor LED floodlights have been around a good few years now and I was wondering if my experience is typical...
How are your LED security floodlights holding up? I'd like to know because mine aren't doing so well. I originally started fitting LED lamps as security lights on the outer walls of my property back in 2014. Originally, all lamps had an associated PIR. I soon learnt that PIR's tended to fail even quicker than the LED lamp itself (including PIRs not in any direct sunlight) so I replaced failed PIR's and LED lamps with separate PIR's and LED lamps. At least now it's an easier task to replace either a PIR or an LED lamp when they inevitably fail.
From 2014 through to 2023, I've fitted probably 14 or 15 LED lamps around my property, all with either their own PIR sensor or wired to a separate PIR sensor. Only one has lasted more than five years - a Luceco, although it's associated PIR failed last year. Most fail at around three years. I can't get an accurate figure for how long these LED lamps have been illuminated during their lifetime but I very much doubt any had more than 1000 hours on them, most far less. As Jim Royle might say, "15000 hours? My arse!"
I imagine the fact that security lights could switch on and off quite frequently may limit their lifespan. Surely these products should last at least five years? Or are my expectations unreasonable? I've used various brands - are any brands known for their longevity? I'd be interested to hear the experience others have with LED outdoor security lamps.
