LG WD12361-RDK washer-dryer not drying
26 Mar 2012
Cheshire
Hello all, I wonder if anyone can help me?
I have an LG washer-dryer combo which I bought in March 2009 (so it's out of warranty). My problem is that it's no longer drying clothes.
The washing machine works superbly, but when you select a dry cycle, the clothes come out sopping wet. If you put *dry* clothes in the drum, even they come out wet.
I've had the local washing machine repair bloke out and he's baffled. There are no blockages, the element is working fine, the valves are operating at the right time etc.
Could it be the motherboard and, if so, does anyone have a clue how much they cost as a spare part?
Cheers for any help
Check you outlet hose is raised above outlet could be siphoning water into machine from sink which would wet clothing on drying cycle.
Hi there I have just fixed this issue myself today.
It helps if you are bit of a handy person, you will find that your air return path is almost blocked with lint at the rear right of the machine. It's white and is attached to the rear of the drum going up to the fan that pushes the air around, also top rear right of machine. You need to undo a lot of screws to get the return air return path from the back, while your there clean the fan as well.
Mine was like a clogged artery no wonder the dryer stopped working properly.
While I love my machine this is a serious floor that LG needs to look in to.
Hope this helps.
