Lifting a Beam
Just thought I would update on progress and success of the job. I got the builders merchant lorry driver to lift the beam centre of the driveway. I was going to use pipes as suggested to maneuver it to the rear but was offered 2 pallet trolleys which used in conjunction with sheets of ply for a smooth running surface got it to the back and in place ready for a lift. I hired 2 Genie lifts and they lifted the beam into place brilliantly!
Thanks to all for your help
UK Kiwi
Hi
In your situation the SE should have broken the beam down into 3 equal sections with steel flange plates to bolt the sections together!
Go back to your SE and ask him 'why not'? A one piece section is ok where its a new build and your craning the beam in, but to expect this on a refurb is asking for a whole lot of trouble!!
Only problem now is that you have the beam on site and drilling holes and cutting beam into 3 equal sections is going to be a bit more problematic than had it been done in the fabricators - or you could send the beam back to the fabricators for the ammendmants. Assuming SE is agreable!
Regards
Hi
I think you missed the boat there bud! :p
Regards
