I can carry out simple electrics, new lights, sockets etc. New kitchen and between it and the main house is an old utility room.At the house end we blocked an old door and unearthed a light switch for the room. I wanted this moved to the kitchen end of the room,so I thought simple ,disconnect switch,put cable into junction box and extend down the room. Switch is an old double switch, I opened it and found 3core and earth. 2 x commons joined by red wire, yellow wire into B 1way, cable red into Bcommon, cable blue was covered in yellow tape and in A 1way.
I terminated the yellow and used the red and blue to feed junction. Light worked fine but then I wanted to isolate light circuit for another job and it refused to turn off at the box. Not sure if wiring is a problem or possibly the old simplex cartridge in main box is faulty.Help
