I have a detached double garage fed with underground armoured cable and fuse box by the builders when the house was new.
In the garage, there are 4 flourescent tube units (linked in series with 1.00 T&E) switched from two switches, one between the garage doors and one at the doorway into the garden.
One of the flourescents is in the floored roof space and comes on with the other 3 units when either of the switches is activated.
That's a bit of a waste of energy and I would like to be able to put in a seperate switch to handle this flourescent.
Can I just add a switch in this supply cable to the unit in the roofspace or do I have to disconnect the current feed and run a new switch to the fuse box along with a new supply cable?
Any comment would be appreciated.
John in Oxfordshire
John in Oxfordshire
