Thanks for the help everyone. I will look at whether I can fit RCBO to the existing CU or move the lighting MCB to the RCD part of the board. I assume this is notifiable?
Are you in England? If so, it would only be notifiable if one considered that one had 'created a new circuit'. I personally don't see that moving the same MCB to the RCD side of the board, or replacing the MCB with an RCBO of same rating ("In") would constitute the creation of a 'new circuit', but others might disagree.
You'll need to dress the wiring carefully, avoiding sharp bends. Also check that the free ends of the L & especially the N (which will curently be in the N bar) wires are long enough to reach the terminals in the RCBO, which will be that much higher up.
