Lighting circuit is on, but one room is still dark?
9 May 2005
Hiya,
This is weird, and I've been scratching my head all day - what has even happened here?
I've removed a bathroom cabinet (with its own lighting), but now the rest of the bathroom ceiling lights have no power.
The lights circuit did trip out, but when the fuse box was reset, the rest of the house lights came back on, but not the bathroom.
The cabinet was on the lighting circuit, and even if I reconnect the cabinet now nothing works now. I've checked the wall switch, but it has no live there either.
Two adjoining rooms have no lights problem, the bathroom (6 spotlights) has no power anymore.
What else should I check? Is there any obvious thing that could cause this?
Could there be an additional trip switch for the bathroom lights which isn't on the fuse panel ?
I can't think why one room would failed failed if the others are ok??
Many thanks for any suggestions.
Yes, there might be a fused switch
somewhere nearby and you blew the fuse -
or a loose wire somewhere.
anything is possible , depending on how it was all wired
how was the Bathroom Cabinet light switched ON / OFF
the lights maybe from a transformer - and not all mains lights
the lights and sockets all WORK every where - ITS ONLY the bathroom lights that do not work
nothing else tripped on consumer unit
Tripped what ?
Fused spur anywhere in room or outside - may or maynot have a switch
Yes, there might be a fused switch View attachment 362825 somewhere nearby and you blew the fuse -
You're quite right - it was a 3A fuse inside the ceiling fan switch. I never use the fan, so forgot about it being a thing.
Isn't this forum great? I run out of ideas, but someone somewhere can always suggest a solution.
Cheers chaps.
