I can't believe the amount of stick some of you are giving this guy - almost half of this topic consists of people bashing his/her choices of home decor rather than answering the question. This place becomes more and more like the plumbing forum with every day that passes.
Indeed, and it is therefore common sense that you shouldn't install a fitting with the potential to generate significant heat near combustible materials, or materials with a low melting point. You'll probably find something relevant in part 4 of BS7671, along with External Influences in the appendices.
I personally don't think the heat generated by five or six CFLs is going to be enough to cause a problem, as there is a fair amount of volume to the space underneath a typical bath. However, it's still a bad idea as per above.
As long as the bath panel is fixed and requires a tool to remove, the area under the bath is indeed unzoned. I can only assume that those who have so far suggested that you can't do as you have proposed are making that statement based on common sense rather than regulation. For example, if you've ever removed an old bath, there's almost always signs of water having made it down behind the tiles and down the wall behind the bath. I'd say the area is liable to damp, despite not being zoned.
Then buy a string of white LEDs, perhaps?
Not being in a zone isn't the issue - you could actually fit lights in the bath itself, provided they were suitable for that location.
A collection of ceiling roses (or batten holders) won't be any use, as there is the issue of someone installing incandescent lamps in them
Ok I sort of see that ( is this a legal requirement)but surely there is the potential of any light fitting being changed
CFLs are no use either, since these still get hot when in use. Being in an enclosed space will only make this worse.
wont that just keep the bath warmer for longer lol ok so i see the point of that but even if they were low wattage would this really be a problem?
You may as well forget about the existing dimmer on the wall, since this could well be at or near it's maximum load anyway, and even if not, the type of lighting suitable for locating under a bath almost certainly won't be compatible with the dimmer.
The dimmer only has 3 low voltage lights so should be ok
and are there not dimmerable fluorescent lights ( or dimmerable ballastsThis is where i am confused - I thought if the under bath area ( with a sealed fixed panel) was unzoned ( as per the previous thread) am i wrong in thinking that if its unzoned then i could put more or less anything (within reason) there (obviously taking into account heat etc)
A realistic solution to this lighting would be LED strips, and if you want different colours, get RGB types so you can set whatever colour you want. These require a dedicated controller, and remote controls are available so the controller and lights would be completely sealed under the bath, and you just need the battery operated remote to switch them on/off, change colours and whatever else.
Such as this: http://www.ultraleds.co.uk/self-adhesive-tape-leds-metre-lumen-metre-p-1517.html
I dont want colour changing just a simple single colourd glow from the bath ( and i have access to so much lighting gel!!)
