I want to run an outside light using the 30 amp power cable in the garage.
Can I take a spur off a power point to a 5 amp fused spur and the use 1mm T&E for the switch and light.
The cabling for the light will be directly on the wall behind the power cabling in the garage with no viible cables showing.
the only point I am unsure of is if it is safe practice to use an FSU unswitched with 2.5mm cable from power point and then 1mm to supply light and switch.
Is this OK
Is this OK
