My house similar sized room, started with two 100W tungsten bulbs, we changed to two chandeliers with three bulbs each, went to 40W each, but before long moved to 60W, as the CFL came in we started fitting 3 x 11W but they looked rotten so when a burst pipe forced us to do repairs we fitted 5 bulb chandeliers at this point we fitted 10 x 8W globe bulbs giving around 3500 lumen of light, however these were useless bulbs on switch on these Philips bulbs were very red, slowly getting brighter, and they were not really bright enough to read with.
So when Lidi did some LED bulbs we gave them a try, first was two 1.8W candle bulbs and then another 8 x 3W this gave us around 2400 lumen but it actually seemed a lot brighter, in fact the brightest the room had ever been, however as time went on we were not so sure if actually brighter or just the colour of bulb making it seem brighter, so bulbs all moved to mothers house and replaced with 10 x 5W LED lights so back up to around the 3500 lumen mark.
Not sure if too bright now, I think using standard lamps to read with is a better idea and have just the 3W lamps, they shine up onto a white ceiling which spreads out the light well, simply using a chandelier where the bulbs face down will change the light output. But at least this should give you an idea
