lighting switch cable seems to be melting
11 Nov 2008
Sussex
In one of my bedrooms I noticed that when I switched the light on, there was kind of crackling noise so i took the cover to have a look and noticed the cables were very sticky and there was some sticky blue fluid on the bottom rim of the cover.My bathroom light, which is on the same circuit ,also tends to flicker on and off , sometimes staying off altogether for some time.Does anyone know what the problem might be? Thanks
green goo/di-isoctyl phthalate
common in wiring around 1965-71, generally does not effect the insulation of cable. I would be check the cable for loose connection and faulty switch contacts.
friend of mine is bringing a new switch for me tomorrow so i'll change that
New switch and cleaning the cable will only be a temporary fix - the problem will return.
All of the cable needs to be replaced.
yes i thought it might need it, so i was looking really in terms of temporary fix
http://www.elekeiroz.com.br/EN/products/MSDS/Dioctyl%20Phthalate%20-%20DOP.pdf
I would clean any residue and check copper is clean on cable ends, wear PPE and isolate circuit prior to this.
what is PPE ? I usually just switch off the trip switch before attempting anything
wingcoax is right about the initials, but rubber is not recommended as a good protector when dealing with phthalates; latex is the best cheap material.
... rubber is not recommended as a good protector when dealing with phthalates; latex is the best cheap material.
I think one probably needs to be careful about the terminology here. AFAIAA 'latex' is a generic term which encompasses hundreds of things (both plant-derived and synthetic), some of which are rubber - and I haven't a clue as to which are (and are not) recommended for use in relation to 'green slime'!.
Kind Regards, John
