Several of the lights in my house occasionally (three or four times in 6 months)flicker and then cut out entirely, after leaving them for a couple of hours they try and switch themselves back on, flicker and then go out again. If all lights are switched off and left for an hour or so they start to work ok again.
It only happens to a section of the circuit (Kitchen <4 spots - 60w each>, Hall <60w>, Bathroom <20w energy, 60w wall and a fan>) so appears to be isolated to one 'arm' of the circuit. These rooms are all an extension of the original house.
It seems to occur when the lights have been switched on and off frequently in a short space of time. I have managed to aggravate it by flicking the kitchen light on and off until it cuts out.
There is an old ceiling rose being used as a junction box on the circuit (not me) which I think is the spur off the light radial - could that be faulty or connections loose?
I did the bathroom lighting myself but this problem had occured once prior to this so I don't think it was me!!!
Any comments would be great.
