hi all,
i have a couple issues with my light fixtures:
1) the fixture wont work at all and i suspect it might be because of an old leak in the bedroom ceiling that's put it out of action (there's a water mark around the fixture)
2) the two-way switch at the top of the stairs isn't connected properly in that it's not fully interchangable. For example, if you turn the light on upstairs, you can go downstairs and it'll switch off and then on from that switch. But if you switch the light off upstairs, you can't switch it on from downstairs! Madness!
Are these issues that an electrician would be able to fix without too much bother? I'm a novice when it comes to these and so would like an idea of what i'd be getting myself in to!
Any input would be appreciated..
