I'd like to use a LightwaveRF in-line dimmer on a light fitting that has a transformer and low voltage bulbs. The dimmer can be set to disable the dimmer function, so provides full 240V when on, but like most LightwaveRF lighting switches, it leaks voltage when off.
I'm trying to find out if the voltage leakage of 2 volts is safe when going into a transformer, rather than 240V LED bulbs.
Thanks.
Thanks.
