There only seems to be about a couple of degrees difference between the cylinder flow and return. I have read here that there should be 11-20 degrees C between the flow to and return from the boiler. What can one do about this? The cylinder has its own 2 port motorised valve, as do the two heating circuits. What is the most efficient temperature to run the boiler at?
