It’s very common.Boiler main switch is on the wall just near the boiler.
Aren't most isolation switches sited near the boiler, why would someone put a boiler main switch in the airing cupboard?
If only there was some way you could remove the fuse to the boiler supply, at the switch next to the boiler....
No you are wrong, the live for the pump MUST be connected to the new boiler, the switched live from the zone valves will already be connected to the existing boiler so that is fine, the new boiler will now need a permanent live as well as the existing switched live, you will also need a system by-pass installed as you have an S plan (if one not already fitted).Ok, that's a relief,
I blame it all on these installers coming round to give me quotes for a system boiler from a vented system.
A couple have said , have to take a wire from the old pump (in the airing cupboard) back to the new boiler.
But looks like, switched live comes from the zone valves and permanent live can really come from a live near the boiler.
I knew that I should have been an electrician really.
Thanks to u and Ian
The reason , your replacement boiler is low water content, when a demand for CH or HW stops the zone valves close and the burner on the boiler stops, however the boiler will still be hot and the boiler will keep running the pump to cool itself, once the boiler is cool enough it will stop the pump
