- Joined
- 29 Jul 2016
- Messages
- 3
- Reaction score
- 0
- Country
I'm looking to add some sockets to my basement to supply a new workbench area. The existing wiring is on a dedicated 2.5mm radial circuit covered by a 32A MCB, and feeds a double socket and boiler (the boiler has a FCU).
I've been led to believe that provided the radial circuit covers an area less than 75m2, I should be able to add additional sockets by simply extending the radial within this area.
My concern is that the existing double socket is being used for a washing machine and tumble dryer, and that given the peak current of these, I might be asking for trouble adding any further appliances on the 2.5mm / 32A combo. I'll be running power tools (saws, sanders, etc), and unlikely to have more than one running at any given time, but my mitre saw is 2kw, so on the rare occasion that I'm sawing with the washing machine (2.4kW) and dryer (1.4kw) both on at the same time, I'd run the risk of exceeding the 27A the wire can handle, without tripping the MCB, or any of the 13A fuses. The existing socket is only about a metre from the consumer unit, and the extended sockets would be less than 10m away.
Am I worrying about nothing, or should I be considering upgrading to 4mm cable, or converting the radial to a ring?
Cheers,
Cheers,
