Wrong yet again You got my post removed but reinforced the image
Thanks Agile - I have gone against contradicting advice from Screwfix forum posters saying to leave alone unless rads dont get hot.
However - the upstair rads got hotter quicker which is exactly the opposite what I would like. So have turned 1st and 2nd floor lockshields down. Much better now - perfectly balanced.
My thoughts were that gravity and longer pipe runs were delaying the time taken for the lounge to heat up
Therefore thanks Agile
Hi ajstone - its me omidknight popping up to comment here and there
In a pumped system, convection is negligible.I think that the 6 metre difference in pressure top rad to bottom rad plays some part in deciding first where the hot water from the boiler goes when it first fires up
It's insignificant.as hot water likes to rise up a pipe again I think its going to go upstairs sooner than downhill - however insignifican to some this may be
Have you come here just to have a go at your installer?I wonder if it was the same expert installer here that also fitted the bath to the wall using a tube of silicone and size 12 screws directly into plasterboard (not even using rawlplugs). Perhaps he also used old plastic pipe brackets as the cistern washers and didnt think it wise to fit a stop end on a unused washing machine valve and fitted plastic right up to the basin flexi`s ?
But does it leak, or wobble, or have any other problem with it?just saying it like it looks like to me
Ive never seen a tube of silicone used before like this before
Thanks for explaining
Mine looks wobbly, but if anyone tries to grab it they find it surprisingly rigid.mine leaks and wobbles
