Hi all, moved into our 4 bed detached 2 1/2 years ago and first winter i topped up the insulation in the loft and had new facias and soffits etc done.
When the temp really dropped i noticed condensation on the underside of the felt (non breathable) so doubled up the soffit vents as the installer only fitted 4 front and back and put the dehumidifier up there and all dried out fine.
This year i again topped up the loft insulation (now about 400mm thick) and checked for condensation when the temp dropped and it had returned-i squeezed in a couple more soffit vents and made sure the insulation was not blocking the vents and also fitted 2 tile vents (tiles are redland regent) to the rear on the house 4 rows down from the ridge and let loose with the dehumidifier and again all dried out fine!
Now 2 weeks later i checked again and its starting to return-the ensuite and bathroom both are vented and my other half only dries the odd item on a radiator-im now at a loss, do i fit 2 more tile vents to the front to match the back? the loft is freezing so insulation is doing it job and i also fitted some pipes as makeshift felt lap vents-what else can i do as there are no signs of the roof leaking!
By the way the house also has cavity wall insulation and the area over the 3rd and 4th bedroom is free from condensation!
Our bedroom had 10 spotlights and i even removed these to help!
Thanks for your replies!
