Some of my novice previous questions on this subject may have you thinking I need more than a structural engineer, but hear me out!
It’s been a couple of years since I finished the extension which is still standing so I’m itching for a new monster DIY project. I’ve built out, so now it’s time to build up.
I’ve a good sized loft, 1925 detached house with a typical roof of the time….. a gable one end, hip the other and a couple of gables sticking out of the face and rear for good measure. There is a massive original 12” steel already in the loft mid way spanning front to back where brick piers have been built off to support the purlins mid way.
My initial thought is to leave the roof as is, plain tiles with friable mortar fillets behind, and just bang a dormer on the back. Then insulate between rafters leaving an air gap the insulate over the top. Throw a floor down, cut a hole in the landing ceiling and Bob’s your uncle.
At the moment I’m unsure on the structural side of things. Firstly the roof. Cutting out the back is sure to throw the roof off balance. I’d be cutting a purlin out alongside a decent proportion of rafters to accommodate the dormer. So that’s going to need some support. Secondly the floor. Clearly new floor joists need adding. The 4x2s currently support the Christmas decorations. But do I need steels? What size? I’m not expecting you lot to answer my how long is a piece of string question just yet. Just thinking out loud.
I suppose the advice I’m after is whether a structural engineer is required for building regs. Also, from my usual YouTube research, every loft conversion I’ve seen has enough steel in to build the Eiffel Tower. I’m wondering if I even need steel with the current big steel in there and some nice mid span supporting walls.
Thoughts and reality check please gents. Remember, tight as a gnats chuff and bloody minded gung ho full steam ahead attitude.
